Docker Not Running Properly on Windows – Need Help?
Hey everyone,
I have been trying to set up Docker on my Windows machine: but I keep running into issues. Every time I try to start Docker Desktop, it either gets stuck on “Starting” or crashes after a while. I have tried reinstalling it a couple of times but that didn’t seem to fix the issue. Here’s what I have done so far ::-
  • Enabled Virtualization in the BIOS.
  • Installed WSL2 (Windows Subsystem for Linux) as Docker recommends.
  • Tried running Docker with Hyper-V enabled and disabled – neither seems to make a difference.
My PC meets the system requirements and I am running Windows 10. I have also checked for Windows updates and Docker Desktop updates and both are up-to-date.
Has anyone else faced similar problems: ?? Could this be an issue with WSL2 or maybe some settings I am missing: ?? Any advice on troubleshooting or steps I can try would be really helpful !!
Thanks in advance for your help… :pray:
With Regards,
David Miller
Do you mind sharing some screenshots, or a small video of you attempting to install DOcker.
From where I am sure we can assist.
