Netscaler course
Can we have the netscaler step by step setup.
To have externals user connect to our Citrix environment
It was great setting up the home lab with ur lessons
Can you expand on what exactly you are looking for? Are you looking for a walkthrough on how to configure Citrix Netscaler (Or as it is now called, Citrix Application Delivery Controller) to access backend resources, such as Citrix Xenapp or Citrix Xendesktop (Now knownas Citrix Virtual Apps and Desktops).
@Rohitgattu What exactly did you have in mind?
Hello Rohitgattu, I am new to your site. Your step by step procedure is absolutely awesome. I always had an issue with creating the SQL for Citrix. You made it easy.
As per the netscaler. If would be so kind as to Configure a Xendesktop / Storefront servers and create a VIP to access a single or a group of machines from the back end. It could be a webserver or a SQL server. Thank You in Advance!!
Sincerely,
Mustafa
@mustafa31 Welcome to My Broken Computer - we are happy to have you join our little site.
Just so I understand what you are looking for. You are looking to integrate a Citrix Application Delivery Controller (formerly known as Citrix Netscaler), with Citrix Virtual Apps and Desktops (Citrix Xendesktop) - specifically the storefront components?
Or are you thinking more along the lines of leveraging the load balancing functionality. Your comment around SQL threw me for a loop, so I am not entirely sure what you are looking for.
